Pin No. | Pin Name | Pin Function |
| ACIN | Wall Adaptor Charge Input Supply |
279 | NC | No Intemal Connection. |
3 | CHG_S | Charge Status Indicator Output (open drain). |
4 | PGOOD | Power Good Indicator Output (open drain). |
5 | GND | Ground. |
6 | ISETA | Wall Adaptor Supply Charge Current Set Point. |
8 | EN | Charge Enable Input (active low). |
10 | BATT | Battery Charge Current Output. |
Exposed Pad(11) | GND | Ground.The exposed pad must be soldered to a large PCB and connected to
GND for maximum power dissipation. |
