这是一个完整的 5 瓦齐纳二极管系列,具有严格的限制和更好的工作特性,体现了氧化硅钝化结的卓越性能。所有这些均采用轴向引线、传递模塑塑料封装,可在所有常见环境条件下提供保护。
功能
- 齐纳电压范围 - 3.3 V 至 200 V
- 根据人体模型,ESD 额定值为 3 级(>16 kV)
- 浪涌额定值高达 180 W @ 8.3 ms
- 多达六个电气参数的最大极限保证
- 提供无铅封装*
最大额定值
Rating | Symbol | Value | Unit | Max.Steady State Power Dissipation
@TL=25°C,Lead Length =3/8 in
Derate above 25C
Junction-to-Lead Thermal Resistance | PD
θJl | 5
40
25 | W
mW/C
°C/W | Operating and Storage
Temperature Range | TJ,Tstg | -65 to +200
(Note 1) | C |
订购信息
Device | Package | Shippingt | 1N53xxB,G | Axial Lead
(Pb-Free) | 1000 Units/Box | 1N53xxBRL,G | Axial Lead
(Pb-Free) |
4000/Tape &Reel |
电气特性
Symbol | Parameter | Vz | Reverse Zener Voltage @Izr | lzr | Reverse Current | Zzr | Maximum Zener Impedance @Izr | Izk | Reverse Current | ZzK | Maximum Zener Impedance @Izk | R | Reverse Leakage Current @VR | VR | Breakdown Voltage | lF | Forward Current | VF | Forward Voltage @IF | lR | Maximum Surge Current @TA=25℃ | △Vz | Reverse Zener Voltage Change | zM | Maximum DC Zener Current |
电气特性(除非另有说明,否则 TA = 25°C,VF = 1.2 V Max @ IF = 1.0 A 适用于所有类型)
Deyicet
(Note 2) | Device
Marking | Zener Voltage (Note 3) | Zener Impedance (Note 3) | Leakage
Current | IR
(Note 4) | △Vz
(Note 5) | zM
(Note 6) | Vz(Volts) | @lzr | Zzr @lZr | Zzk @lzk | lzk | lR @VR | Min | Nom | Max | mA | Q | Q | mA | uA Max | Volts | A | Volts | mA | 1N5333B
1N5334B
1N5335B
1N5336B
1N5337B | 1N5333B
1N5334B
1N5335B
1N5336B
1N5337B | 3.14
3.42
3.71
4.09
4.47 | 3.3
3.6
3.9
4.3
4.7 | 3.47
3.78
4.10
4.52
4.94 | 380
350
320
290
260 |
3
2.5 | 400
500
500
500
450 |
| 300
150
50
10
5 |
7 | 20
18.7
17.6
16.4
15.3 | 0.85
0.8
0.54
0.49
0.44 | 1440
1320
1220
1100
1010 | 1N5338B
1N5339B
1N5340B
1N5341B
1N5342B | 1N5338B
1N5339B
1N5340B
1N5341B
1N5342B | 4.85
5.32
5.70
5.89
6.46 | 5.1
5.6
6.0
6.2
6.8 | 5.36
5.88
6.30
6.51
7.14 | 240
220
200
200
175 |
1.5
1
1 | 400
400
300
200
200 | 7 | 1
10 | 233 | 14.4
127
12.4
11.5 | 0.39
0.25
0.19
0.1
0.15 | 930
865
790
765
700 | 1N5343B
1N5344B
1N5345B
1N5346B
1N5347B | 1N5343B
1N5344B
1N5345B
1N5346B
1N5347B | 7.13
7.79
8.27
8.65
9.50 | 7.5
8.2
8.7
9.1
10 | 7.88
8.61
9.14
9.56
10.5 | 175
150
150
150
125 |
1.5
1.5 | 200
200
200
150
125 |
1
1 | 10
10
10
7.5
5 | 5.7
6.2
6.6
6.9
7.6 | 10.7
10
9.5
9.2
8.6 | 0.15
0.2
0.2
0.22
0.22 | 630
580
545
520
475 |
- 183.92 KB
- 这是一个完整的 5 瓦齐纳二极管系列,具有严格的限制和更好的工作特性,体现了氧化硅钝化结的卓越性能。所 ...
