The SN9C2808ZSJG is a high resolution Webcam controller. Besides improved image quality, this generation of ISP
supports wide dynamic range (WDR) and vertical lens distortion correction (VLDC) to bring better visual experiences.
It not only brings less noise image for human eye but also makes the analysis work in machine-vision easier. For
modern high resolution and AI applications, SN9C2808ZSJG would be a higher performance and cost effective
choice.
The major functions of SN9C2808ZSJG include controlling the CMOS sensor, receiving the image data, converting it
to video stream, and then sending data to the host via USB. It’s compliant with USB 2.0 High-Speed (HS) and USB
Video Class (UVC) 1.1/1.5 over ISO or Bulk in transfer. Compliance with the public standards makes
SN9C2808ZSJG easy to be integrated into various fields of applications that need high quality video like high
resolution tablet built-in camera, camcorder, surveillance, video conference and machine vision (AI).
SN9C2808ZSJG supports both parallel and MIPI-CSI2 1/2/4-lane CMOS sensor interfaces and the performance of
ISP is up to 3264x2448@15fps or up to 1920x1080@60fps. The high performance Motion-JPEG engine and bit rate
controller provides various compression ratios to meet bandwidth requirement. This system is controlled by the
embedded micro-controller with the built-in statistics of AE / AWB. The flexible architecture includes the mask ROM,
internal RAM and external serial-flash which can store the customized codes and parameters.
There are 3 built-in regulators and no needs of external oscillator, these features make it able to further save BOM
and PCB area. The SN9C2808ZSJG is the best choice for the compact modern electronic product design.
