ABSOLUTE MAXIMUM RATINGS (Tc=25 °℃,unless otherwise noted) |
PARAMETER | SYMBOL | LIMIT | UNIT |
Drain-source voltage | Vbs | 100 |
Gate-source voltage | Vas | ±20 |
Continuous drain current | Vas at 10 V | Tc=25 ℃ | lp | 9.2 | A |
Tc=100 ℃ | 6.5 |
Pulsed drain current a | IbM | 37 |
Linear derating factor |
| 0.40 | W/C |
Single pulse avalanche energy b | EAs | 200 | mJ |
Repetitive avalanche current a | IAR | 9.2 | A |
Repetitive avalanche energy a | EAR | 6.0 | mJ |
Maximum power dissipation | Tc=25 ℃ | Pp | 60 | W |
Peak diode recovery dV/dt C | dV/dt | 5.5 | V/ns |
Operating junction and storage temperature range | Tj,Tstg | -55 to +175 | ℃ |
Soldering recommendations (peak temperature)d | For 10 s |
| 300 |
Mounting torque | 6-32 or M3 screw |
| 10 | lbf·in |
1.1 | N·m |
