NCE82H140采用先进的沟道技术和设计,具有出色的 RDS(ON),栅极电荷低。它可用于各种应用。
一般特性
VDS = 82V,ID = 140A
RDS(ON) < 6mΩ @ VGS=10V (典型值:4.3mΩ)
特殊工艺技术实现高 ESD 能力
高密度电池设计,实现超低 Rdson
完全特性化的雪崩电压和电流
具有高 EAS 的良好稳定性和一致性
优异的封装,散热性能好
功率开关应用
硬开关和高频电路
不间断电源
包装标记和订购信息
Deyice Marking | Device | Device Package | Reel Size | Tape width | Quantity | NCE82H140 | NCE82H140 | TO-220-31 |
绝对最大额定值(TC=25℃,除非另有说明)
Parameter | Symbol | Limit | Unit | Drain-Source Voltage | VDs | 82 | V | Gate-Source Voltage | VGs | ±20 | V | Drain Current-Continuous | lo | 140 | A | Drain Current-Continuous(Tc=100℃ | b(100℃) | 99 | A | Pulsed Drain Current | lbM | 480 | A | Maximum Power Dissipatio | Po | 220 | W | Derating facto |
| 1.47 | WIC | Single pulse avalanche energy Noe⁵ | EAs | 1200 | mJ | Operating Junction and Storage Temperature Range | Tj,Tsrg | 55 To 175 | ℃ |
电气特性(TC=25℃,除非另有说明)
Parameter | Symbol | Condition | Min | Typ | Max | Unit | Off Characteristics | Drain-Source Breakdown Voltage | BVpss | Vcs=0V Ip=250μA | 82 |
| V | Zero Gate Voltage Drain Current | lbss | Vps=82V,Vgs=0V |
| 1 | μA | Gate-Body Leakage Current | GSS | Vcs=±20V,Vps=0V |
| ±100 | nA | On Characteristics(Note 3) | Gate Threshold Voltage | Vgs(th | Vps=Vcs,lp=250μA | 2 | 3 | 4 | V | Drain-Source On-State Resistance | Rps(ON | Vgs=10V,lp=20A |
| 4.3 | 6.0 | mΩ | Forward Transconductance | gFS | Vps=5V,Ip=20A | 65 |
一 |
| S | Dynamic Characteristics(Note4) | nput Capacitance | Ciss | Vps=40V,Vcs=0V,
F=1.0MHz |
| 7900 | 一 | PF | Output Capacitance | Coss |
| 445 |
| PF | Reverse Transfer Capacitance | Crss |
| 384 | 一 | PF | Switching Characterictice(Note | Turn-on Delay Time | td(on) | Vpp=30V,RL=1Ω
Vcs=10V,RgEn=2.5Q |
| 23 | 一 | nS | Turn-on Rise Time | tr |
| 42 |
| nS | Turn-Off Delay Time | ta(ofn) |
| 75 |
| nS | Turn-Off Fall Time | tf |
| 26 |
一 | nS | Total Gate Charge | Qg | Vps=40V,Ip=20A
Vcs=10V |
| 158 |
| nC | Gate-Source Charge | Qgs |
| 32 |
| nC | Gate-Drain Charge | Qgd |
| 51 |
| nC | Drain-Source Diode Characteristics | Diode Forward Voltage (Note 3) | Vsp | Vcs=0V,Is=140A |
| 一 | 1.2 | V | Jiode Forward Current (Note 2 | ls |
一 | 140 | A | Reverse Recovery Time | tr | TJ=25℃,IF =20A
di/dt =100A/us(Note3 |
| 50 |
一 | nS | Reverse Recovery Charge | Qrr |
| 110 |
一 | nC |
- 370.84 KB
1 RD币 购买记录
- NCE82H140采用先进的沟道技术和设计,具有出色的 RDS(ON),栅极电荷低。它可用于各种应用。 ...
