该系列器件采用先进的沟槽栅超级结技术和设计,具有出色的 RDS(ON),栅极电荷低。这款超级结 MOSFET 符合业界对 PFC、AC/DC 电源转换和工业电源应用的 AC-DC SMPS 要求。
高压器件新技术
低导通电阻和低传导损耗
小型封装
超低栅极电荷,降低驱动要求
100% 通过雪崩测试
符合 ROHS 标准
功率因数校正(PFC)
开关模式电源(SMPS)
不间断电源(UPS)
包装标记和订购信息
Deyice | Device Package | Marking | NCE60T2K2I | TO-251 | NCE60T2K2I | NCE60T2K2K | TO-252 | NCE60T2K2K |
表 1. 绝对最大额定值 (TC=25℃)
Parameter | Symbol | Value | Unit | Drain-Source Voltage (Vcs=0V) | Vbs | 600 | V | Gate-Source Voltage (Vps=0V),AC(f>1 Hz) | Vgs | ±30 | V | Continuous Drain Current at Tc=25℃ | lb(Dc) | 2 | A | Continuous Drain Current at Tc=100℃ | o(pc) | 1.25 | A | (Note 1)
Pulsed drain current | lDM (pluse) | 8 | A | Maximum Power Dissipation(Tc=25℃)
Derate above 25℃ |
DL] | 21
0.168 | W
W/C | Single pulse avalanche energy | (Note2) | EAs | 12 | mJ | Avalanche current(Note 1) | IAR | 0.3 | A | Repetitive Avalanche energy,tar limited by Tjmax
(Note 1) | EAR | 0.06 | mJ |
Parameter | Symbol | Value | Unit | Drain Source voltage slope,Vbs ≤480 V, | dv/dt | 50 | V/ns | Reverse diode dv/dt,Vps ≤480 V,Isp<Ip | dv/dt | 15 | V/ns | Operating Junction and Storage Temperature Range | T.T
1J,I STG | -55…+150 | ℃ |
表 2. 热特性Parameter | Symbol | Value | Unit | Thermal Resistance,Junction-to-Case(Maximum) | Rthc | 5.95 | °CW | Thermal Resistance,Junction-to-Ambient (Maximum) | RthJA | 75 | C W |
- 457.8 KB
- 该系列器件采用先进的沟槽栅超级结技术和设计,具有出色的 RDS(ON),栅极电荷低。这款超级结 MOSFET 符合业 ...
