YD2030 是一款单片音频功率放大器集成电路。
*所需外部元件极少。
*高电流输出和高工作电压。
*低谐波和交叉失真。
*内置过温保护
*所有引脚之间均有短路保护。
*输出晶体管的安全工作区。
方框图
绝对最大额定值(Tamb=25℃)
PARAMETER | SYMBOL | VALUE | UNIT | Supply Voltage | Vcc/VEE | ±22 | V | Peak Output Current (internally limited) | lop | 3.5 | A | Total Power Dissipation at Tcase=90℃ | PD | 20 | W | Ambient operating temperature | Topr | -20~+75 | ℃ | Storage Temperature | Tstg | -40~+150 | ℃ |
电气特性
(参见测试电路,Vcc/VEE=±14V,f=1kHz,Tamb=25℃)
PARAMETER | SYMBOL | TEST CONDITIONS | MIN | TYP | MAX | UNIT | Supply Voltage | Vcc/VEE | | ±6 | | 士22 | V | Quiescent Drain Current | Iccq | | | 40 | 60 | mA | Input Bias Current | lib | Vcc/VEE=±22V | | 0.2 | 2 | μ A | Input Offset Voltage | Vis | | 士2 | ±20 | mV | Input Offset Current | lis | | 十20 | 士200 | nA | Output Power | Po | RL=4Ω, | THD=0.5%, | 12 | 14 | | W | THD=10%. | | 18 | | W | R=8Ω | THD=0.5% | 8 | 9 | | W | THD=10% | | 11 | | W | Power Bandwidth | BW | Po=15W,RL=4Ω | 10 | | 140k | Hz | Open Loop Voltage Gain | Gvo | | | 90 | | dB | Close Loop Voltage Gain | Gv | | 29.5 | 30 | 30.5 | dB | Total Harmonic
Distortion | THD | Po=0.1~12W,R₁=4Ω
f=40Hz~15kHz | | 0.2 | 0.5 | % | Po=0.1~8W,RL=8()
f=40Hz~15kHz | | 0.1 | 0.5 | Input Noise Voltage | VNI | B=22Hz~22kHz | | 3 | 10 | μV | Input Noise Current | Ini | B=22Hz~22kHz | | 80 | 200 | pA | Input Resistance(pin1) | Zi | Open Loop, | 0.5 | 5 | | MΩ | Supply Voltage
Rejection | RR | RL=4(2,Rg=22k()
f=100Hz,Gv=30dB, | 40 | 50 | | dB | Thermal Shut-Down
Junction Temperature | Tj | | | 145 | | ℃ |
应用电路
(1) YD2030 双电源应用
- 162.93 KB
1 RD币 购买记录
- YD2030 是一款单片音频功率放大器集成电路。
