1、介绍
SDR735 器件的技术信息主要包含在表 1-1 中列出的文档中。
表1-1 SDR735主要文档
Document number | Document title | 80-PP662-1 | SDR735 Data Sheet | 80-PP662-4
(this document) | SDR735 设备修订指南 | 80-PP662-5 | SDR735 设计指南/培训幻灯片 | 80-PP662-5A | |
1.1 范围和目标受众
本设备修订指南指出了迄今为止发布的所有 SDR735 示例的问题。 它适用于设计、测试或评估包含 SDR735 器件的产品的新产品开发人员。
2、设备识别
SDR735 设备通过其顶部表面上的标记和识别寄存器的内容进行识别; 这些识别技术在第 2.1 节中进行了描述。 第 2.2 节到第 2.3 节介绍了有关每种样本类型的更多详细信息。
2.1 零件打标
设备标记(俯视图,未按比例)
图 2-1 设备标记(俯视图,未按比例)
表2-1 设备标记线定义
Line | Marking | Description | C1 | | Qualcomm name | P1 | | Qualcomm Technologies, Inc. (QTI) product name
n SDR735 | P2 | [Variant] | Device variant information
n See Table 2-2 for the assigned values. | | Blank or random | Space between line P2 and T1 is reserved for optional additional information. | T1 | •
FAYWWXXX | Pin 1 or pin A1 indicator F = supply source code
n F = J for Samsung (SEC) | |
| n F = H for GLOBALFOUNDRIES (GF ) | |
| A = assembly site code | |
| n A = E for ASE, Taiwan | |
| n A = K for SPIL, Taiwan | |
| n A = H for JCET STATS ChipPAC, Korea (SCK) | |
| Y = single/last digit of year | |
| WW = two-digit work week of year specified by Y | |
| XXX = traceability number |
2.2 每种样品类型的设备标识
表2-2 设备标识详细信息
Device | Sample type | Variant (PRR)
P = product configuration code RR = product revision
code | Hardware version | Source configuration code (S) 1 | Date code (YWW) | Comments | Sample date | Bands supported 2 | | GSM | CDMA 1xA, 1xEV-DOr0
and 1xEV DOrA, | TD- SCDMA | | | NR sub-6 GHz | SDR735 | ES1 | 000 | v1.0 (SEC) | 0 | – | B1, B2, B4, B5, | 850, 900, | BC0, BC1, | B34, | B1, B2, B3, B4, B5, B7, | B34, B38, B39, | n1, n2, n3, n5, n7, | 1/15/2020 | |
| B6, B8, B19 | 1800, 1900 | BC10 | B39 | B8, B9, B10, B11, B12, | B40, B41, B42, | n8, n12, n20, n28, |
| B13, B14, B17, B18, | B43, B46, B48 | n40, n41, n48, |
| B19, B20, B21, B25, |
| n66, n71, n77, |
| B26, B27, B28, B29, |
| n78, n79 |
| B30, B32, B66, B71 |
| | ES2 | 001 | v2.0 (SEC) | 0 | – | B1, B2, B4, B5, | 850, 900, | BC0, BC1, | B34, | B1, B2, B3, B4, B5, B7, | B34, B38, B39, | n1, n2, n3, n5, n7, | 5/11/2020 | | | | | B6, B8, B19 | 1800, 1900 | BC10 | B39 | B8, B9, B10, B11, B12, B13, B14, B17, B18, | B40, B41, B42, B43, B46, B48 | n8, n12, n20, n28, n40, n41, n48, | v1.1 (GF) | 1 | 7/30/2021 | |
| n66, n71, n77, |
| n78, n79 |
| | CS | 001 | v2.0 (SEC) | 0 | n ASE: YWW ≥ | B1, B2, B4, B5, | 850, 900, | BC0, BC1, | B34, | B1, B2, B3, B4, B5, B7, B8, B9, B10, B11, B12, B13, B14, B17, B18, B19, B20, B21, B25, B26, B27, B28, B29, B30, B32, B66, B68, B71 | B34, B38, B39, | n1, n2, n3, n5, n7, | 6/30/2020 | | | | 024
n SPIL: YWW ≥ 024
n SCK: YWW ≥ | B6, B8, B19 | 1800, 1900 | BC10 | B39 | B40, B41, B42, B43, B46, B48 | n8, n12, n20, n28, n40, n41, n48, n66, n70, n71, n77, n78, n79 | | v2.0 (SEC) | 1 | |
| | 024 |
| | v1.1 (GF) | 1 | n ASE: YWW ≥ |
| | 8/30/2021 | |
| | 133 |
| | n SPIL: YWW ≥ |
| | 133 |
| | n SCK: YWW ≥ |
| | 134 |
| 注:
1、S 是源配置代码,用于识别特定样品类型发货时可用的所有合格模具制造源组合。 S 值的定义见表 2-3。
2、检查软件发行说明以了解支持频段的软件功能。
表2-3 源配置码
S value | F value = J | F value = H | 0 | Samsung (SEC) | – | 1 | Samsung (SEC) | GLOBALFOUNDRIES (GF) |
完整Qualcomm高通SDR735 设备修订指南下载附件查看
