硬件发布文件列表
RK3528A_Hardware Document release Note and File List_V10_20230712.xlsx
01_Common Document
RK3528A Hardware Design Guide-CN-V1.0-20230712.pdf
Rockchip RK3528A EVB1 User Guide_CN_20230712.pdf
RK3528A Power Consumption Test Report V1.0_20220712_CN .xlsx
RK3528A_Methods for Processing Unused Pins_V1.0_20230712.xlsx
RK3528A_Package_PinLength_V1.0_20230712_EN.xlsx
RK3528A_PinOut_V1.0_20230712.xlsx
Rockchip RK3528A datasheet V1.0-20230712
02_DDR Template
RK3528A_Template_DDR3P416DD4_39x43_1056MHz_V10_20230712
RK3528A_Template_DDR3P416DD4_39x43_1056MHz_V10_20230712.brd
RK3528A_Template_DDR3P416DD4_39x43_1056MHz_V10_20230712核心板设计重点说明.doc
RK3528A_Template_DDR3P416DD4_39x43_1056MHz_V10_20230712.DSN
RK3528A_Template_DDR3P416DD4_39x43_1056MHz_V10_20230712叠层阻抗.xlsx
RK3528A_Template_DDR4P216DD6_17x35_1056MHz_V10_20230712
RK3528A_Template_DDR4P216DD6_17x35_1056MHz_V10_20230712.brd
RK3528A_Template_DDR4P216DD6_17x35_1056MHz_V10_20230712核心板设计重点说明.doc
RK3528A_Template_DDR4P216DD6_17x35_1056MHz_V10_20230712.DSN
RK3528A_Template_DDR4P216DD6_17x35_1056MHz_V10_20230712叠层阻抗.xls
RK3528A_Template_DDR4P216SD4_32x39_1056MHz_V10_20230712
RK3528A_Template_DDR4P216SD4_32x39_1056MHz_V10_20230712.brd
RK3528A_Template_DDR4P216SD4_32x39_1056MHz_V10_20230712核心板设计重点说明.doc
RK3528A_Template_DDR4P216SD4_32x39_1056MHz_V10_20230712.DSN
RK3528A_Template_DDR4P216SD4_32x39_1056MHz_V10_20230712叠层阻抗.xlsx
RK3528A_TEMPLATE_DDR4P416DD4_36X39_1056MHZ_V10_20230712
RK3528A_Template_DDR4P416DD4_36x39_1056MHz_V10_20230712.brd
RK35RK3528A_Template_DDR4P416DD4_36x39_1056MHz_V10_20230712核心板设计重点说明.doc
RK3528A_TEMPLATE_DDR4P416DD4_36X39_1056MHZ_V10_20230712.DSN
RK3528A_Template_DDR4P416DD4_36x39_1056MHz_V10_20230712叠层阻抗.xlsx
RK3528A_Template_LP3S178P132SD4_24x34_1056Mhz_V10_20230712
RK3528A_Template_LP3S178P132SD4_24x34_1056Mhz_V10_20230712.brd
RK3528A_Template_LP3S178P132SD4_24x34_1056Mhz_V10_20230712核心板设计重点说明.doc
RK3528A_Template_LP3S178P132SD4_24x34_1056Mhz_V10_20230712.DSN
RK3528A_Template_LP3S178P132SD4_24x34_1056Mhz_V10_20230712叠层阻抗.xlsx
RK3528A_Template_LP4D200P132SD4_28x34_1056Mhz_V10_20230712
RK3528A_Template_LP4D200P132SD4_28x34_1056Mhz_V10_20230712.brd
RK3528A_Template_LP4D200P132SD4_28x34_1056Mhz_V10_20230712核心板设计重点说明.doc
RK3528A_Template_LP4D200P132SD4_28x34_1056Mhz_V10_20230712.DSN
RK3528A_Template_LP4D200P132SD4_28x34_1056Mhz_V10_20230712阻抗表.xlsx
RK3528A_Template_LP4xD200P132SD4_30x34_1056Mhz_V10_20230712
RK3528A_Template_LP4xD200P132SD4_30x34_1056Mhz_V10_20230712.brd
RK3528A_Template_LP4xD200P132SD4_30x34_1056Mhz_V10_20230712核心板设计重点说明.doc
RK3528A_Template_LP4xD200P132SD4_30x34_1056Mhz_V10_20230712.DSN
RK3528A_Template_LP4xD200P132SD4_30x34_1056Mhz_V10_20230712叠层阻抗.xlsx
RK3528A_Template_LP4XD200P132SD6_20x29_1056Mhz_V10_20230712
RK3528A_Template_LP4XD200P132SD6_20x29_1056Mhz_V10_20230712.brd
RK3528A_Template_LP4XD200P132SD6_20x29_1056Mhz_V10_20230712核心板设计重点说明.doc
RK3528A_Template_LP4XD200P132SD6_20x29_1056Mhz_V10_20230712.DSN
RK3528A_Template_LP4XD200P132SD6_20x29_1056Mhz_V10_20230712叠层阻抗.xlsx
02_Key Device Specifications
1_CDW-47822CS-VE1_BT50无屏蔽盖_20220701.pdf
2_16_QHRF20279(new).pdf
2.0 AF 90度卷边弯脚.pdf
2.54 单排直针 L=16.5 -Model.pdf
B5819W SOD-123.pdf
BAT54S SOT-23.pdf
CF4024M00012BEA40000(3225 24-12高温).pdf
CF4040M00009T5025G42(3225 40-9).pdf
DDR3_k4b4g1646e-bc_rev1.0-1.5v.pdf
DDR4_SDRAM MT40A512M16TB-062ER(D8BPK) .pdf
DS-0043规格书.pdf
ESD5341N.pdf
ESD5451N.pdf
ETA3409.pdf
ETA8120.pdf
GY58-1X1非屏蔽无灯带筋 Model (1).pdf
H1601G(1).pdf
H20030-1 规格图 铜壳 HDMI2.1.pdf
ICSRC-52128SFR(1).pdf
IRM-3638T-X.pdf
LPDDR3_K4E6E304EC-EGCG_178F_11x11.5_R10.pdf
LPDDR4_MT53D512M16D1, MT53D512M32D2, MT53D1024M32D4.pdf
LPDDR4X 16Gb K4U6E3S4AA-MGCL_200F_10x15_1.00.00.pdf
PJ-320D贴片式(1).pdf
SGM2036.pdf
SGM2036S Preliminary Datasheet_20220711.pdf
SGM89000_REV.B.1_20120917.pdf
SY6280 Rev0.3_Datasheet.pdf
TMI3112H_DS_EN_V0.1.pdf
TS06B25SN Model (1).pdf
网络变压器UTH16C04H.pdf
03_Reference Design
RK3528A 参考图版本和DDR核心模板说明_20230712.xlsx
RK_DEMO4_RK3528A_DDR4P216SD4
RK_DEMO5_RK3528A_LP4D200P132SD4
RK3528A_BOX_REF
瑞芯微RK3528A参考设计资料(包含DDR模板、设计指南、规格书等)资料下载
