查看: 126|回复: 1
[资料] 三星S5K3M5SX05 CMOS 1300万像素 参数
发表于 2024-1-9 10:26:19 | 显示全部楼层 |阅读模式 来自 广东省深圳市
S5K3M5SX05_Data Sheet_REV0.03
1.2 Features
·13Mp sensor with 1/3.4"optics
·Unit Pixel size
·Effective resolution
·Active resolution
·Color Filter
·Shutter Type
·Max. Normal Frame Rate
·Max. Video Frame Rate
Data rate
ADC Accuracy
Dual sensor synchronize
Interfaces:
Fine interface frequency control using additional dedicated PLL for EMl avoidance and integration
flexibility.
MIPI CSI2: four lanes (1.6Gbps per lane)
Output formats: RAW10
Control interface:
CCI(Camera Control Interface) High speed I2C-compatible-Two-wire serial communication circuit up to 1MHz
:1.0pm
:4208(H)x3120(M)
:4224(H)x3136(V)
:RGB Bayer Pattern
: Electronic rolling shutter and global reset
:30fps@Full
:120fps@WVGA(crop)
:1,600Mbps/lane
:10bits
·64 Kbit on-chip OTP memory Mapped BPC and chip ID
·Analog gain x16
·Vertical and horizontal flip mode
·Continuous frame capture mode
·2/2-average-sub-sampling readout
·Pixel skip readout function
·Mapped Bad pixel correction
·Built-in test pattern generation
·Supply voltage
·Operating temperature
:2.8V for analog, 1.8V or 2.8V for l/O, and 1.05V for digital core supply
:-20°℃ to+70C
发表于 2024-1-16 15:36:43 | 显示全部楼层 来自 上海市浦东新区
版主,你好,没看到有附件,谢谢
